whiny ford pump getting thrown in the bush
gnardoom
bc
4L
I have a 92 ranger with a 4.0L. I need a saginaw pump with a serpentine pulley and the same fittings as my truck, I dont care if I have to notch the bracket. Which gm vehicles have pumps set up like this? I was thinking maybe an astro van
gnardoom
bc
4L
1st gen ranger?
Dave
southern New Jersey
3L
Is this link supposed to go to a specific part? Or just the Parts America home page? If it's supposed to go to a specific part, the link did not work. But I would like to see the part.
Do most Ford PS pumps whine? Mine does and I hate it. My 3.0L is the quietest engine I've ever owned but the whining PS pump annoys me.
Dave
Totalled
Law Enforcement
Tumwater, Wa
8 rabid gophers
Dave
Put your zip code in and it will pull up the part page. Anyway..
It's a GM Saginaw pump that's made to replace ford plastic res pumps.
It's spec't for a 1978 application, so you'll probably need a type 2 fitting pressure hose (78-89). The type 3 fitting hose (1990-up) will screw in but won't seal.
Dave
southern New Jersey
3L
Very cool....I like it. I'm going to look into getting one of them. The Saginaw in my E350 is quiet. I'm guessing the pressure and flow from the Saginaw is close (enough) to the Ford pump that it will work correctly? Thanks again.
Dave
Dave
southern New Jersey
3L
Totalled,
Check this out.....the picture you posted has the pump for $93.99. When I entered my zip, the pump came back as $65.48. That's weird. What's a different zipcode have to do with it?
rickcdewitt
5
nor-cal
4-0 swap
does the factory serpentine pulley press onto the t-bird pump?
gnardoom
bc
4L
I want one from a wrecker, I dont know if its easier to use an econoline pump or a gm pump, I dont know which gm vehicles will have the right pulley
Dave
southern New Jersey
3L
The PS pump in the picture that Totalled posted is way different than a GM Saginaw or one from an Econoline. The Saginaw in my Econoline is just like what GM used. The Saginaw in the picture is specially made to bolt to Ford PS brackets. A GM/Econoline PS pump will not be a direct bolt it. You will be way ahead of the game if you start with the Saginaw Totalled posted about.
Dave
gnardoom
bc
4L
can a parts store order one or do you have to buy it from that site
Dave
southern New Jersey
3L
Get the Cardone part number and bring it to your favorite parts store....Many parts stores can cross a p/n over to their p/n.
Or....
Go to the Cardone webpage that has the PS pump, click on the link that says "See all vehicles this product fits". Pick any vehicle from the list and tell the parts guys you need a PS pump for it. He will most likely give you a Ford pump. Make sure you tell him you need the optional Saginaw pump that was used....not the more commonly used Ford pump. For example: my '78 F150 is on the list and it has a Ford pump. BUT apparently the Saginaw was optional so make sure to get the Saginaw.
Good luck.
Dave
