While the engine is out....
Sultan
Sultan, WA
2.9
So I need to yank my engine out what things should I take care of while it is out?
Background, it is an 86 B2 with manual tranny 4x4. It has sat for the last ten years in garage. It runs great but needs a throw out bearing.
Thanks, Rick
Why are you pulling the engine for a throwout bearing?
Sultan
Sultan, WA
2.9
Yea great question. I want to pull the engine to detail the engine bay and replace anything that could have gone bad after 10 years of sitting. While the engine is out I will fix the bearing. Yea kinda backwards.
Sultan
Sultan, WA
2.9
Yap in the list. How about rear main seal?
Ryannn
13
Carson City, NV
Make sure you have a seal puller... like 10$ at NAPA and why not? its right there pops in and out.
nitrofan1
Man without a Ranger
MTOTM Winner
19
Chattanooga, Tennessee
Subaru
EJ251
10 years? Rear main, oil pan & top end (intake, valve cover) gaskets. Hell, put a new water pump on it since it's out!
RangerBoy94
24
Northern California
360CDI
GEt a master gasket kit and be set for a long time. Also get a clutch/pressure plate kit.
84bluebronco2
13
Central New York
While the engine is out, get a 4.0/M5OD. :D
Sultan
Sultan, WA
2.9
HAHAHA I am not going to put a 4.0 in it. It runs great. Much better than my 88 Ranger.
4.0B2
151
Walls, MS
4.0 v6
i agree w/ this guy :yahoo::D:thefinger:
other than that
FULL gasket set. rubber valve cover ones, not cork. valve steam seals on the heads. lifters(if you got the money). relap the valves in the heads. resurface the heads. oil pump. clean out the oil pan good. check the mains.
basically, pull it all apart. do the small simple stuff. check everything. :icon_bounceblue:
RangerBoy94
24
Northern California
360CDI
other than that
This!
That pretty much what I did to mine and I'm happy I did it and it wasn't that hard to do.
Slave cylinder too.
Also, I will say that the engine is usually much easier to put back in place if you drop the transmission out, and a transmission is much easier to line up to an engine than an engine is to a transmission.
Sultan
Sultan, WA
2.9
Thank you for the advise "Sound Man". Do you do audio for a living?
Hah, I wish.
I am a technician at a Ford dealership by profession. I dabble in sound on the side and run the board for services at church. I don't do anything professionally and I'm just starting to get into car audio stuff. That was prompted by the realization that the radio I put in my Ranger has a built in graphic equalizer.
