which transmission do i have??
strvger
19
the land of 2 seasons-Winter and getting ready for
2.3
ok, 1983 ranger, 2.8, 5 speed. the 5 speed replaced the original 4 speed. 5 speed came from a b2. on mine, the shifting forks are only accessible by removing the bottom cover. most of the threads about forks problems say to get to them by removing the shifter cover. can't get to them that way on mine. trying to match mine up in the tech library, i thought i had an FM-145, but guess i'm wrong as i can't get to the forks from the top. yeah, they're stuck and trying to get them unstuck! not having much luck so far.
Explorin94
Law Enforcement
Firefighter
EMT / Paramedic
19
Farmington Il.
Does your transmission have a access plate on the bottom? If so then you are correct with it being a FM-145 or a 146. The M5OD-R1 has the top plate on it that has the shiftrails with it.
3,614
:worthless:
I can probably figure it out for you, but I need to see it.
Hahnsb2
36
Battle Ground WA
Ford-Dodge
4.0-5.2 Turbo
What year was the B2 it came from?
Hahnsb2
36
Battle Ground WA
Ford-Dodge
4.0-5.2 Turbo
I'm guessing it would be a TK5.
3,614
