Where to buy double platinum spark plugs?
Tamsar20
Portland, Oregon
Ford Ranger XLT
I've been reading up on what spark plugs to buy for a tune up on a 1994 4.0l ranger. The consensus seems to be the motorcraft double platinums, but I can't seem to find anywhere that sells them. If anyone can send me in the right direction that'd be great. Also is there any brand for the spark plug wires that people like?
Bird76Mojo
1,266
IL
The 94 isn't a wasted spark system to my knowledge, is it? So the double platinum's might be overkill.. On the later SOHC 4.0 you have one cylinder bank firing the plug the traditional way, but the other bank fires from the bottom electrode to the top.. That's why the double plats are recommended in that engine.
But here ya go anyway: https://www.rockauto.com/en/catalog/ford,1994,ranger,4.0l+v6,1137989,ignition,spark+plug,7212
Rockauto.com 5% discount code: 176497081139004586
cbxer55
767
Midwest City, Oklahoma
I buy mine from the NAPA store 1.5 miles from where I live. But, Vato Zone, Advance Auto and Slo'Reilly's should all have them.
Dirtman
13,329
41N 75W
It's up there.
It's down there.
Round.
I poop in the furnace.
If it doesn't have a distributor it's waste spark.
Bird76Mojo
1,266
IL
I stand corrected, but do all wasted spark systems fire one bank in reverse?? That's the question..
Dirtman
13,329
41N 75W
It's up there.
It's down there.
Round.
Yup. That's the "waste" of the waste spark. One bank fires from electrode to ground on the compression stroke while the other side fires from ground to electrode (the waste side) on the exhaust stroke. All ford distributor-less ignition systems work this way. They only use one coil per every two cylinders so one cylinder always gets a normal spark, and one gets a normal spark and a waste spark. The only systems that don't operate this way are modern coil on plug ignitions since each cylinder gets its own coil.
Bird76Mojo
1,266
IL
Doesn't waste spark refer to cylinders being fired on the exhaust stroke?
Yup... https://en.wikipedia.org/wiki/Wasted_spark
Dirtman
13,329
41N 75W
It's up there.
It's down there.
Round.
Yep that's what I done did just did say I did.
dirtymike
112
knoxville TN
Ranger lwb
1 inch spacers
P23575R15
Do unto others then Split-probasti me et chognuisti me
..and i was reading so attentively.
