Where can I get a gas tank?
Mike 257
Lee's Summit Missouri
6cyl 4.0
I have a 1997 Ranger and I need a new gas tank. All the local junk yards puncture holes in there tanks and the parts stores cant get tanks.
3,614
Rowdy Fitzgerald
Hog hunter
Firefighter
EMT / Paramedic
372
Nevada
5.0,4.0
Solid Axle Swap 4x4
6”
Rock auto
Mike 257
6cyl 4.0
Rock auto dont carry tanks, and LMC only carries tanks up to 1988
6
New Orleans
'98
'94
'98
For
2.5, 2.3 & 3.0
Trying to be a better Christian than non-christians.
Pull-A-Part in Tuscan, AZ has a 1995 ranger that might be compatible. I'm just saying that you may need to abandon the thought of local junk yard. Check the local Ford dealer however, and be willing to pay a lot. Check eBay. You may have to even consider a fuel cell and have a custom body shop install it.
Assess the risks and take your own risks of repairing the existing one you have - it's plastic. But I would remove it and clean it out with soap and water first.
Mike 257
6cyl 4.0
I went to replace the fuel pump only to find the tabs for the locking ring were rotted off the tank.
Mike 257
6cyl 4.0
Nothing on ebay. Im also not sure what years are compatible as far as gas tanks are concerned. I know that 1993 tru 97 are compatible as far as most parts go, but Im not sure about gas tanks.
Die.Fledermaus
4
State of Jefferson, USA
2.0 (4 Cylinder)
2.9
0"
If the yards are drilling used tanks to drain them, then the tank should still be solid enough to reuse.
How big of a hole are they putting in?
Mike 257
6cyl 4.0
They puncture three triangular holes about one inch. Then they have the balls to put $25 price tag on there price list with $5 core charge. Who would buy a tank with these holes?
Die.Fledermaus
4
2.0 (4 Cylinder)
2.9
0"
Why people do what they do is also beyond me. Your general location in your user profile might be helpful, the same with a wanted ad.
Mike 257
6cyl 4.0
I will update my profile, Thank You .
Andy D
10
Marshfield MA
The Rat
4.0 OHV
to prevent Found On the Road Dead, Fix Or Repair Daily
Uhmhhn can you repair/ rig the bad top of your tank? Maybe grafting parts from a holed JY tank. They have to puncture the tanks to remove the gas for liability and safety reasons.
Mike 257
6cyl 4.0
I thought about trying to repair my tank. Im not sure what is easier repairing mine or the junkyard with holes.
harbt95
Near Plattsburgh NY
I have two of them in my back yard, one for ex cab one for std cab. Where are you
Sent from my iPad using Tapatalk
