Wheel Bearing Issues
susieranger
'92
dremel cutting tool
Do you guys know what kind of dremel bit would be good to try and cut off a frozen wheel bearing. I looked around Home Depot last night and didn't see anything but a cutter for soft metal. Thanks.
bluovaldude
Use the cut off wheel. I think it is about the size of a 50 cent peice, but you really only want to notch the bearing, and use a chisel not knock it out.
ILLEGALCONCEPTS
4
Pittsburgh PA
2.3 Modified
Make sure you get the reinforced cut off wheels. If you try and use just the regular ones, you'll spend more time changing wheels out then cutting.
James
