atikovi
- Apr 17, 2010
- 1
- Suburban Washington DC
The owners manual says 7.2 quarts. I flushed out the system and changed the hoses so there was little water left in the block. I got a whole gallon of 100% antifreeze back in plus maybe one or two quarts of additional water. (I did use some of the antifreeze in the over flow bottle.) After driving it around so everything gets mixed, my coolant tester shows the mix is only good down to -15F when a 50/50 mix should be at -34F. So obviously it holds more than 7.2 quarts. So how much of this mix do I drain out and replace with 100% antifreeze to get it closer to -34F?
