What year did Ford stop putting the 9" rear in the Bronco?
merace19
Like title says. What year? Also what transfer case in a 84 with 5.0
ZMan
MTOTM Winner
406
Medina, Ohio
Ford Rangers
4/4, bagged
I believe '79 was the last year.
merace19
No it was sometime in the 80's. I just want to pin point the year.
Sevensecondsuv
7
Northern IL
Many
All Fords!
Many
My buddy has an 86 with a 9" and 4.10s. But he isn't the original owner so there is no way to tell if that's what it came with from Ford or not.
JohnnyO
Moderator Emeritus
Forum Staff - Retired
2,855
Pittsburgh, PA
2.3 EcoBoost
1.5"
Some time in the early 80's. At least for a while I think if you got a 351 engine you got a 9", and with a I-6 or 302 you got an 8.8".
merace19
Does axle code H9 help?
AllanD
134
East-Central Pennsylvania
1987... sorta
'93 4.0
They switch mid-year in 1984.
AD
wvfarmboy
03 ranger 4.0
99 ranger 3.0
rear end
almost sure it was 83 because i had a 82 that ahd a 9 in ford and dad had a 83 thet had the newer eone 8.8 i think
Ozwynn
200
Berrien Springs, MI
RE Interceptor
If you can't go through it or around it, then go over it.
there are carb'd 351/c6 powered 86 big broncos that have a 9". the 8.8 was used with fuel injected Broncos
Sevensecondsuv
7
Northern IL
Many
All Fords!
Many
^that's what my buddy's 86 has, the Carb'd 351 H.O. and C6
Will
514
Gnaw Bone, Indiana
Toyota
Are you trying to identify the axle? A 9" has no rear cover--no bolts when viewed from the rear. An 8.8 has a rear cover--bolts.
UrbanRedneckKid
17
Cass Co, Missouri
AD
I've never doubted you Allan, but I've seen them in '85s, and I know it was factory well checked the numbers. Maybe it was an option...?
wahlstrom1
J-man HD Mech
2011 Truck of The Year
21
Edmonton Alberta
Ya, seen them in 86's with 351's up here as well. Like everything Ford did, there was probably a few crossover years/models.
shon
I believe the transfer case if not a 205 will be the BW1356. I am actually trying to find a 95 or 96 in great shape. I will have both ends of the spectrum then...
merace19
79 was last year for 205 in bronco
