- Aug 14, 2007
- Reaction score
- 983
- Location
- UT
- Make / Model
- Ford
- Engine Type
- 4.0 V6
- Manual
- 2WD / 4WD
- 4WD
- Total Lift
- 5
- Tire Size
- 33
From your earlier post, it sounds like your fuel pressure is good.
Did you ever do a compression test?? That will tell us a lot.
Also, the timing needs to be correct. You set it with the spout disconnected. I can normally break loose the dizzy bolt with a ratcheting wrench, from the top.
What is your TPS voltage reading with the throttle closed? Fully open?
