What vehicles used the Borg-Warner 13-54 transfer case?
Adam33
Does anyone know what vehicles used the Borg-Warner 13-54 transfer case? From my reach I have identified the following:
1) Bronco II 1983 to 1995
2) Explorers from 91-94
3) Rangers - but not sure of exact dates?
Did any other vehicles use this case?
jdm4721
I'm pretty sure my 99 Ranger has a 1354 case.
Sent from my SM-G900V using Tapatalk
rusty ol ranger
2.9 Mafia-Don
7,533
Michigan
177 CID
Didnt the 87ish-96 F150s run it to?
Mac
183
C. Wisconsin
2000
199
From tech library - Rangers, Mazda and Explorers
BW1354 1990-1995 (Electric Shift) with speedo hole, with sensor hole fixed front output yoke
1990-1995 All (manual shift)
1995-1998 (Electric Shift) rear circular flange front fixed yoke with speedo hole, w/o sensor hole
1998-2000 (Electric Shift) rear circular flange, front cup yoke w/o speedo hole, w/o sensor hole,
2000-2004 (Electric Shift) rear circular flange, front cup yoke w/o speedo hole, w/o sensor hole, w/o shift on the fly
2000-2004 Manual shift, rear circular flange, front cup yoke w/o speedo hole, w/p sensor hole
fastpakr
2,834
Roanoke, VA
Rangers and Bronco II's from 83-89 will have the 1350. I think the 1354 transition occurred in 1990 but someone else can confirm.
fastpakr
2,834
Roanoke, VA
Full size in those years is a 1356 as I recall. Definitely not a1350/1354 though. After that they started getting the 4406.
AzLizard
12
TUCSON, AZ
1985
4.0 2.8
That's what I was thinking.
I got mine from a 90 b2.
I am concerned by the fact that the OP thinks he learned the 1995 Bronco II had a BW1354 since 1990 was the last year for the BII.
turbo91xlt
63
Goshen, NY
1992
Basically every RBV with a part time 4wd setup used the 1354 transfer case after ~11/89. Simply put if your RBV had a D35 front axle stock, it also has a 1354 transfer case.
Manual transfer cases can be found in rangers all the way up to 1997 (excluding the limited production '02-'03 FX4 Level II units).
Adam33
Thanks for your replies.
Out of the vehicles that used the 1354 transfer case, do you know if any used a metal mode fork in the case? As most the ones I have seen are plastic.
Adam32
If the transition occurred in 1990, what is the latest year of a vehicle with a 1345?
fangotango306
8
sc michigan
None yet
You have 2 threads with 2 accounts asking the same questions or am i going crazy? What are you trying to accomplish by discovering the transitional timeline of the mode fork material. Early ones are a cast zinc/aluminum alloy. Later and most aftermarket replacements are plastic but the 1354m i think were all metal. What are you trying to do?
fangotango306
8
sc michigan
None yet
Oh and if you need parts i have 4 bw1350s and 5 or 6 bw1354s and one 1354m but i wont part my m.
