What trans do you got?
coolen
Nova Scotia
I'm curious as to what everyone is running in their rangers for a tranny after the v8 swap. I initially had a top loader 3 speed, cast iron monster.. Last year I put in the top loader 3spd with OD...brought my rpms down crusing- and saved a few bucks each fill up. I'd like to have another gear, so would that only leave me with a t-5?
I could put an auto in it....but I'm not sure if I'd like that.......what are you running??
Jbrown1238
6
Largo, Fl
306
None
World Class T5, Ford Racing "Z" version.
ick
Mesa AZ
Just started my swap but I'll be using the 4r70w auto.
Sent from my SAMSUNG-SM-G920A using Tapatalk
ascentpro
ASE Certified Tech
Provo, UT
I used a small block ZF5 from a 90s F250. It's a 5 speed. 1st is granny low and 5th is overdrive. Awesome transmission.
RangerSVT
Oct 09 OTOTM
ASE Certified Tech
53
TRS since 2002 - NW KY
GT-40 5.0L EFI W/AC
If you're 2wd, the T5 would be my first choice, if you're a stock daily driven 4wd, I'd go with the M5ODR2, if a weekend wheeler or offroader, the ZF 5dpd...
SVT
coolen
Nova Scotia
Just a 2wd...I'm starting to look around for a t-5 now. Think there will be much to be concerned with where the shifter comes through the floor, I dunno where the shifter will end up compared to the toploader...........
don4331
1,352
Calgary, AB
5.3
I went with M5ODR2 from a V-6 F-150 with my V-8 swap as everything was in same spot: connector for reverse/neutral, hydraulic clutch, transmission mount and drive shaft (call me lazy). I also wanted the 3.91:1 first from the M5OD versus the 2.97:1 from the T-5.
If you do through Mr. Brown's build, you will see how he handled the clutch, the mount and modifying the floor to fit. If you don't want cut the floor; you can always swap the tail shaft housing from an S-10 onto the T-5, and shifter will basically be in the stock position.
coolen
Nova Scotia
Im not having any luck with the t5. I did however find a M5ODR2. I had the truck out for a late night cruise lastnight and noticed that the throw out bearing is getting noisy. Any suggestions on what I would ask for ordering this bearing? I had the t-18 in it and now the 3 spd with od, I'm not sure what that one is called. It has an aluminium case.
Any suggestions?
Thanks. I was thinking just to order one for a 87 mustang since that is what the engine is from.......
Mac
183
C. Wisconsin
2000
199
Tremec 3550 with mid-shift for 4x2 and T-5 for the 4x4.
Dave
Mightyfordranger
157
Ohio
3in
Clean your room before you criticise the world.
I'm running kind of an odd ball compared to u guys but its an aod like out of an 80s f150 would NOT!! Recommend anyone use this setup the TV cable is a pain and u have to get an adapter to use it with the Borg warnner t case
coolen
Nova Scotia
Grrrrr, the guy that has the M5ODR2 said he doesn't have the shifter stick!
bobbywalter
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
i use a 4l80 in my ranger. its brutally strong.
i would argue the aod with some simple mods or the 4r70 if your using the system of efi that supports it would be the best trans you can use with ford windsors.
but if your stuck on a manual...the r2 is the most cost effective for a 4x4. t5 if you can find one for a 2wd v8.
both are weak for serious power and traction.
regardless, i have destroyed them all.:dunno:
300I6Ranger4x4
Chilliwack, BC
351w
We must do the things we think we cannot
SVT
bump**
Well said. I went... err, going.. 351 carb'd/zf5/np205. Still have to slap it in. Hopfully 2nd week of october its goin all in! Getting close to everything i need for it. But ya, I'm a huge zf5 fan. For 4wd that is.
