What Lamp is this?
OkieGentleman
Oklahoma City, OK
3.0 L V6
Fix it like it has to last a 100 Years.
FRONT LAMPS A.jpg:annoyed:
I have a 1998 Ranger that I bought last weekend. I tested all of the lights and everything seems to be ok, but the two clear upper lamp units do not work.
I have been trying to figure this lamp arrangement out. I cannot find these listed anywhere on the wiring diagram. I have checked the lights and as near as I can tell the lamp that is circled does not show up on any circuit in the Haynes manual I have. The lamp has an orange bulb in the unit with two wires running to it ( a black and a brown) drivers side I cannot see the passenger side connection.
If someone could tell me what I am looking at I would appreciate it. I think I want to change the orange bulbs to white led and use them for day light running lamps. Yes I know I can probably put the relay in and use my head lamps, but I do not want to do it that way.
Doofy
7
Alaska
Shit Happens...Then You Die.
Corner marker. Should be an Amber 194 bulb.
OkieGentleman
Oklahoma City, OK
3.0 L V6
Found it, Thanks for the reply. The Chiltons manual shows the wiring,plus I found a mod in the forum that I like and will apply to my lights
This will very likely get you pulled over and ticketed.
