what is this?
Charles
1988
ford Bronco II
Same problem as before, It's got gas in it, but it's not pumping all the time.
I'm not getting gas up to the second pump, I removed the line and tried. I can hear the pump in the tank, so I'm thinking it's ok. The fuel filter comes after the second pump, so what is this, another filter?
xr75er
7
ford/dodge/ford
2.9 stock
yes it is and make sure to remove the pressure from the system before un sccrewing the lower section.
Psychopete
29
FW, IN
Depending on what year that's from, it might have a filter in it, it might not. It's actually a fuel reservoir.
CarsonChris68
northern Nevada
1987 BII
2.9L
If your not getting fuel up to the second pump then your screen on your tank pump might be clogged.
Take off the upper rear line and turn the key on. If you still get no fuel you have a problem with the tank pump.
That's a reservoir. If you determine it's the issue, just get a new one, they are like $25.
