what is reverse rotation?
pineypower1186
November STOTM Winner
Taberancle, NJ
302 C.I.D.
my buddy is goin to put gears in his truck but doesnt kno what he has. he found the ratio he wants but doesnt kno what reverse rotation is. an outside source as well as myself believe it is a high pinion setup(which his truck is not) does anyone else have any input on this question?
scooter
October OTOTM Winner
50
N.W. Oklahoma
5.0L
I REALLLLY dont understand your question, but I'll try to answer it anyways......:dunno:
If it is a high pinion, it is reverse rotation.
Most carriers have a ratio split also.... When you are ordering gears, be sure to tell whoever you are ording them from, to check and make sure that the ratio will still fit your carrier.
Sunk
125
Everett, WA
3.5 Eco
It could also mean reverse cut. Some axles use the same name/number for front and rear (D35, D44, D60.. etc.). Reverse cut gears are for the front axle, since you don't want to be using the coast side of the gear when driving forward.
brendank
It's only money...
Forum Staff - Retired
Saskatoon, Saskatchewan
Reverse rotation gears are a myth.
projectnitemare
8
Osceola Mills, Pa
396W
Thank you. So many people tell me about reverse rotation and it like nails down a chalkboard to me. I'm not trying to be a jerk, just a little OCD thing. Reverse cut gears are for a front axle so that you are putting torque on the drive side of the gear instead of the coast side like on a standard front ring and pinion. They are usually a good idea if you are replacing an older traditional ring and pinion since most people get throttle happy going forward and not as much in reverse. What kind of truck does your buddy have? Someone should be able to help.
Matt
scooter
50
N.W. Oklahoma
5.0L
Matt
I got what your asking now....
MR.N said:
6: "Reverse Rotation "
This term is just wrong. Neither the axle nor the axle shafts travel in a reverse motion, or travel 'backwards' compared to a regular housing. This term only shows the ignorance of the person or (worse yet) company using it.
LINK TO INFO.....http://77cj.littlekeylime.com/Dana44_2.htm
