What do I need to grab...
86MUDRCJ
8
Sheridan, CA
2.9
I might be getting a 3/4 ton Dana44 but the kicker is I ha ave to pull the axle itself. Anything besides everything that's on the axle I should grab?
86MUDRCJ
8
Sheridan, CA
2.9
I mean a 3/4 Dana 60
1badexplorer
Firefighter
4
Sutersville Pa
3.0, 501, 7.3psd, 351c, 351w
Front axle or rear? what year truck is it coming out of and how do you plan to put it in? leafs or coils?
86MUDRCJ
8
Sheridan, CA
2.9
It's a rear axle out of a 74 f150 and I'm just gonna use leafs.
1badexplorer
Firefighter
4
Sutersville Pa
A F150 shouldn't have a Dana 60 axle. A F150 should have a 9". Does it have 8 bolt wheels? Either way grab the u bolt top plates because they will have the correct spacing for the diameter axle tube you are using. It might not hurt to grab the driveshaft so you have the end you can adapt to yours if you have to.
86MUDRCJ
8
Sheridan, CA
2.9
I'm sorry it's a f250. It has 8 lug wheels.
