29
San Marcos, Texas
B3000
Made the mistake of parking under a tree...
For 2 weeks.
Washed off 30 tons of bird poop.
Ray
racsan
4,505
central ohio
ford/escape
2.5 (4 Cylinder)
2.5/151 I-4
the grey-t escape
@scotts90ranger - yours a 2.3 lima? Ive had issues with every 2.3 Ive ever had getting temp up, with every new part I could buy. Blocking off rad helps, just watch it when it gets warm out, they will overheat- eventually.
Grumpaw
1,504
Virginia
Ford Ranger XL
Stock
Stock
Stock 225/70/15
I don't count birthday's anymore...just happy to be looking down at the ground instead of looking up
ericbphoto
Overlander in development
16,750
Wellford, SC
6"
scotts90ranger
4,499
Dayton Oregon
2.3 Turbo
Yessir, I'm used to the low coolant temp on the gauge, that's normal, the '90 has been like that for the last 20 years I've had it (with I think 3 different engines now) but it always has had good heat output, unless below freezing fan off floor/defrost will bake you out of the thing without turning the blend door some. On the '97 it runs cool but the heater output is not warm, under 50F it is enough to defrost the windows and take the chill off but gets cooler with more heater fan in both heater output and coolant temp.
I'm assuming it's heater core plugged inside and outside, coolant looked old and rusty when I got it and there was a lot of mouse nest junk in the dash... Heater core is the one job I was hoping I didn't have to do to this thing, would have rather had the '89-94 dash, that's a half beer job if you take your time... I pulled the heater fan months ago I think and didn't find anything in the fan.
2drxploder
436
usa
ranger
347
lower
235 on 15s
got trickflow valve spring kit finished on heads, not fun!
Roert42
5,035
Kintersville, PA
Ranger XLT
4.0 SOHC
Drained the transmission. Clean the crust off the pan and painted it with rubberized undercoating.
Also, drained the coolant.
Probably put the new fluids in tomorrow.
mtnrgr
765
California
6" Skyjacker, with 1.5" coil spacers, custom radius arms, custom traction bars
31x10.50
Lord God is my guardian
Drove to the high desert again for a few days, and decided to give my ole friend a well deserved cleaning.
Saddle Tramp
752
Florida
Put it to work again.
lil_Blue_Ford
6,235
Butler, PA, USSA
4.9L
Pulled the red Ranger out of my backyard to discover a fuel leak, pulled the bed and cobbled up a repair to the leaking line. Used the little bit of rubber line I had on hand plus a piece of aluminum line that I bulged the ends. Still have to fix a cracked leaf spring but hoping to have it on the road by the end of the week
Alan_nc
140
US
Ranger Splash
Ah Sunday. Floyd got to go with me to have coffee with the guys.
We solved most of the worlds problems but left a few for this forum.
3,614
Ranger got the day off. Drove it to church and back like a little old lady.
The B2 got worked though. Moved three of my grandfather's tractors from his place to mine. A POS MTD built Huskee that I'm going to try and trade for a Sears Custom7, and two late 60s-ish JD 110s that be bought as a lot at an auction. Not sure what his plan was, except to restore at least one of the Deers, so I'm gonna try to make at least one functioning law tractor out of them.
fred m
89
Tallahassee, Florida
12.5 cups
I broke in my hitch, which I’ve had for years but don’t think I’ve ever used before. All my trailers weigh >1 ton and I usually pull them with the ‘66 Dodge. I pulled a small trailer with some furniture and other junk about 300 miles home from my house in Alabama.
RF tire is starting to separate but I limped it home the last 10 miles or so. It’s a 2 year old Hankook with 5/32” left.
51526
51528
2drxploder
436
usa
ranger
347
lower
235 on 15s
degreased/cleaned, and painted several parts of motor, frame rails and new calibers. cut stock front coils, installed 5.0 motor mounts, a-arms, tierods and shocks. had to order some seals for wheel bearings before i can finish up the front susp.
yall prefer to or not use any sealer (copper spray etc) on gaskets when assembling the 5.0?
