What causes idle to drop slightly then back up? - 2000 B4000
Jm2576
7
Tacoma, WA
Mazda B4000
The engine idles normally for a while then the idle drops slightly for a few seconds, then idles back up. What causes this? Is it the AC clutch kicking on? Normally I would not be concerned as it seems like normal engine operation, but recently the weather has changed to cold and damp and now it idles a lot lower than it did when the weather was warmer.
rubydist
866
Denver
Ford Ranger FX4
Sounds like the iac may be sticking.
Jm2576
7
Tacoma, WA
Mazda B4000
Thanks. I've never messed with The IAC. I will take it off and have a look & clean it up. Is it possible to test it somehow?
rumblecloud
1,133
48022
Ranger Splash
1-1/2 inch front leveling
Stock
What's the worst that could happen?
only tning I can recommend is to start the vehicle, let it warm. Then unplug the IAC. If the idle drops and or stalls, it is working.
Pulling and cleaning may help. There is an article on how to do that in the tech section HERE
Jm2576
7
Tacoma, WA
Mazda B4000
Thanks for the info! After reading that article I definitely think this is the issue. I am also getting that occasional howling noise as mentioned in the article.
Jm2576
7
Tacoma, WA
Mazda B4000
Update:
I unplugged the IAC while the truck was running and the idle dropped down a little but it didn't stall. I took it off and cleaned it keeping the motor upright. I'm not ready to replace it yet as new ones are $75. It seemed to run a little better and the idle didn't drop down at regular intervals like it did before. Does anyone know what the big black knob on the side of it is for? See attached Pic.
rubydist
866
Denver
Ford Ranger FX4
That is simply an air vent cover.
