What Bolts Are needed ?
DonCoso
Natales , Chile
2.9 L
Hi , i want to know what ( and how many ) bolts y have to put in a BII to make a 3 In body lift , i ask because in the region i am ( chile , patagonia ), is impossible to get a brand new kit , so y will make the block spacers :icon_welder: , but don´t know what bolts are required . thanks
Boggin
48
welcome to TRS. I think you will need 10 but I'm not 100% sure
DonCoso
Natales , Chile
2.9 L
BlackBII
Ranger Custom
Truck of Month
982
UT
You are correct
Nathan123
Millersburg Pennsylvania
2.9 Litre
The lengths sound right because i used 4 and 6 inch bolts with no body lift just stock bushings. The long ones are the very back most ones. I used 1/2" grade 8 bolts and where the nut would touch the bushing a fender washer not just a a regular washer and I remember using washers to shim a few bolts because the threaded section was slightly to short so buy extra standard washers.
DonCoso
Natales , Chile
2.9 L
bad news , the only store that exist here , have only grade 5 and 8" and 10" bolts :sad: , any suggestions ? ideas ? , can use these bolts or are unsafe ? :icon_confused: .
thanks
DonCoso
Natales , Chile
2.9 L
thanks
can i use the 5 grade bolts ?
Junk Collector
Truck of Month
4,802
Rapid City SD
I'd use grade 8 but grade 5 should work fine too. Depending on how much thread you need, you could probably use the 8" and 10" ones and cut an inch off. Dunno what your budget is but maybe Fastenal would ship stuff to you too.
http://www.fastenal.com/web/home.ex
kimcrwbr1
46
maplevalley WA
2.8l
thanks alaskan155 , so the main bolts i have to buy are :
qty size
8 7/16" (12mm) x 7" (180mm)
2 7/16" (12mm) x 9" (23mm)
10 washers 7/16"
is that correct or i miss something . :icon_confused:
Spacers and steering extension I believe
DonCoso
Natales , Chile
2.9 L
Here is the actual status of my work :
i do some body work , paint , add spacers to front coils , put a whell spacer , 6 bolt pattern to use my k5 rims , and i buy new MT tires , actually i'm waiting the bolts ( i buy it in a near city )..
still working hard :icon_welder: and waiting to test it :icon_hornsup:
now i´will show some pitures of the BII .
now i need a :beer: ,
bb
when the bolts come i will post some picts of the body lift :D
No members online now.
