what am i missing
b2rich
Lake Oswego, OR
whats an engine?
i am "trying" to install my leveling springs. Im good until i get to the nut that holds the retainer in. be cause of the concave of the retainer i cant get a good grip on the nut with a 1-1/8 wrench. :dunno:
Little X
SW VA
Use a 1 1/8 deep socket and several extensions which go all the way through the top of the spring, and to your ratchet.
b2rich
Lake Oswego, OR
whats an engine?
D'oh
That is to easy, i want to do it the hard way.
thanks
superds
80
ND
Ford Bronco II
2" body. 1.5" coil spring spacers/rear block
You could also try to lower or raise that end of the suspension with a jack to compress the spring to get a better angle on the nut. But, if you have 1 1/8" socket, that is easier.
b2rich
Lake Oswego, OR
whats an engine?
ya, tried that. just couldnt get enough to make a good grip on the nut with the retainer in the way. ill get a socket to get the nut off.:icon_confused::D
trail B2
8
North Eastern Ca.
If you don't have any spacers under the spring anymore it takes a pretty deep socket.I at least finish it with a wrench lowering and raising like superds.
b2rich
Lake Oswego, OR
whats an engine?
it still has the little factory spacer on top of the lower seat. should i remove that if im going to be using the existing shocks? rs5039. the leveling coils are from skyjacker.
superds
80
ND
Ford Bronco II
I think you'll be ok to leave the factory spacer on there. The 1/2" or so (from memory, correct me if I'm wrong) shouldn't have that much effect on the shock travel.
b2rich
Lake Oswego, OR
whats an engine?
ya, there 1/2 at the most.
Thanks for the responses.
