Weird engine problems
scoutbuff
FORD
Ok so I have a 88 BII with a 2.9L v6. this thing seems to have two problems. #1 would be a intermittent lifter/lifters ticking. This has gotten worse in the few months I've owned it. At first it sounded like one lifter that would tick for a few seconds up to a minute. Now it can be one or multiple. I took the valve cover off on the side that sounded the worst. Nothing loose. So I changed the oil and it got better for about two weeks. Now it's back again..... Need some ideas. this is a low mileage engine and shouldn't be running this bad.
Problem #2 is a weird sputter or loss of power after the engine starts to warm up. It runs ok cold, and ok all the way warmed up, but about half way warmed up it sputters and will hardly run. Changed the fuel filter. Checked the cap, rotor. wires. checked all connections to the coil, distributor. I'm at a loss. Maybe the control module or the coil? Don't know what to check? Any ideas would be great....Thanks:icon_confused:
richard booth
28
Tacoma wa
2.9 for now.
possibly the thick film module on the distributor? sounds like you covered most everything else. Depending on the miles on your 2.9 the pushrods can wear out on the ends, was the oil cap moisture free? I have had an intake gasket leak a little water into the top end and I thought it was a cracked head but turned out I could have just tightened the very loose intake bolts and possibly solved new ticking issue I encountered? Glad I did top end gaskets though as motor has run great for over a year now w 214,000.
DocRoche
I researched this ( problem 2) a bit because Im prepared to have the same issue as soon as I get mine to not immediately die after starting. Many have mentioned the EGR valve being the cause of this. I'm not 100% sure it will fix the situation, but Ive seen it enough to at least be considered.
Slammin Sam
4
Western Colorado
2.9
1987 was the last year for the EGR valve, so it won't be a problem for the OP.
