warn tras4mer brush guard mounting
That_4.0_ranger
156
Appleton,W.A.
4 inch
33X12.50-15
i got a warn trans4mer brush guard i was told it came off a toyota and i was wondering if anyone has any ideas about mounting it
Uncle Gump
Token Old Guy
TRS 25th Anniversary
13,532
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
dvdswan
2,904
Seattle, WA
Ranger XLT 2WD
Cut off the front frame ends of a toyota and weld it to your frame. Problem solved.
Seriously, I would take the bumper off the truck, leave the mounting brackets on, and see where everything lines up. From there you will be able to see if it is going to be a simple mounting setup or a major fab needed setup.
Heck, it could be as simple as getting a 1' length of 6x6 angle iron and using that.
racsan
4,497
central ohio
ford/escape
2.5 (4 Cylinder)
2.5/151 I-4
the grey-t escape
Heres the one I have on the ranger, the brackets clamp to the frame and go forward to the grille guard.
