Volvo fuel injectors
red85
7
Kitchener, Ontario, CANADA
306 ci
I have an opportunity to pick up a set of injectors from a 91 Volvo 740 Turbo. They are physically identical to all the Ford injectors I have seen. I want to use these in my turbo swap on my 94 Ranger. Will they be adequate running 8-10# of boost on an LA3 ECM?
Sevensecondsuv
7
Northern IL
Many
All Fords!
Many
What flow rate are they? Anything other than the 35 lb/hr that the LA3 is calibrated for and it won't run right. That is unless you have a means to tune the LA3 and change the calibration.
dieselboy740
86 bronco2
they are like 32 ish...get a 3 bar fpr in there and should be ok.. I would get a set of brown tops from a svo though. 36lb/hr iirc i have 8 of the volvo injectors i tune volvo's too.
Davis
8
Long Beach, CA
the brown tops are 35 lb/hr at 39psi, but yeah it's basically the same
red85
7
306 ci
I got a set of SVO brown tops in the mail today! I am starting to get pumped about this swap. I just put a new clutch in the truck about a year ago. Am I going to have to change my pressure plate to make this work with my M5OD?
AllanD
135
East-Central Pennsylvania
1987... sorta
'93 4.0
The SVO injectors are the same as the Turbocoupe injectors
UNLESS you managed to buy yourself a set of
the "Green top" EARLY SVO injectors which are only 24lb/hr.
There is no telling what impedience the Volvo injectors are and a mismatch ELECTRICALLY is just as bad as anything else you can do.
Frankly the Stock TC injectors are good to well in excess of 350hp, so I can't imagine what purpose "improvement" would serve.
AD
