vibration question?? help me!?
SuperRanger91
2.9 v6 4.0 hopefully soon
OK when I'm going down the road my truck vibrates a lot and its all in the seat so it must be coming from the rear. I broke my short rear drive shaft and had it professionally rebuilt. Could it be out of balance or would a bad pinion bearing cause it to vibrate also?? And it did vibrate before I broke the shaft so I'm thinking its the bearing. And the vibration gets worse as I speed up so if I'm on the interstate and let it vibrates bad and if I let out of the gas or let it out of gear its even worse so what could it be??
Will
514
Gnaw Bone, Indiana
Toyota
Is the truck lifted? If you have a simple, single u-joint at each end, the angle of the joints has to be the same. The joints also have to be oriented the same--which the driveshaft shop knows. It seems like the truck has a lift on it, maybe a tall one, and that the rear axle needs shimmed to point it at the transfer case.
Pictures and details would help.
SuperRanger91
Its stock, its a super cab so it has the two shafts in back and the stock size tires, I had 31s on it for a while and it vibrated less and I haven't crawled under it to see if my rear flange has play in it. Should I start by checking that?
jhammel85
Guest
Might want to try rotating your tires to see if it changes too.
AgPete139
09/2014 OTOTM Winner
61
Houston, TX
4.0L OHV
Solid Axle Swap 4x4
~9"
35"x12.50"x17"
Manually crawl underneath and shake your driveshaft. It could be the center support / carrier bearing, connecting both halves of the driveshaft. The rubber wears out over time.
I wouldn't blame it on the rear axle pinion bearing just yet. If that goes, then your gears are out of mesh, and you'll definitely hear a grinding humming sound.
And like Will suggested: check your u-joints.
SuperRanger91
Thanks for all the help and I'll have to get under it soon because I have replaced all the u joints and when I broke my short shaft the shop put in a new carrier bearing so I'll have to check it all over again. Thanks guys and I'll get back with ya soon
