V8 Swap What Transmission??
Samwilcox41
Washougal
So I want to swap a 302 into my 83 ranger and I’m thinking about using the T5 transmission but I want to know if I can use 4wd with it. Do I need a special adapter? Is there a T5 that can fit the transfer case ?
lvwill
143
Las Vegas Nv.
2.3 EcoBoost
2.3 Ecoboost
M5r2 from 97+ f150 with 4.2 v6 is your best bet.
Samwilcox41
Washougal
I would much rather go with the 5.0 V8 but why would you recommend this one because it is easier for 4wd?
ericbphoto
Overlander in development
TRS 25th Anniversary
16,767
Wellford, SC
6"
I believe he’s just recommending that transmission. That combination gets you a good transmission with the bell housing bolt pattern you need and ready for transfer case.
don4331
1,356
Calgary, AB
5.3
The Essex V-6 (3.8, 3.9 & 4.2) has the same bolt pattern as the Windsor V-8 (255, 289, 302 & 351*). So, a M5R2 bolts to back of your 5.0. And the M5R2 plugs into the hydraulic clutch of your Ranger - same slave cylinder as the M5R1. Lastly, the M5R2 has a 3.97:1 1st gear; useful for a 4wd truck.
And there are M5R2 with transfer case extension/shaft. While the Ranger 1350/4 cases won't bolt up, the F-150 cases do. As do a number of Jeep & Dodge ones.
Note: It is easier to find 4.6 V-8 M5R2s in 4x4s, and 4x2 4.2 M5R2 in which case, you need to swap the rear housing/shaft into the v-6 transmission. But you are left with enough parts to make a 4x2 4.6 V-8 M5R2 that you can sell to get some of your money back. The 4.6 Modular V-8 having a different pattern than the Windsor V-8, the bellhousings being integral to the transmission case.
There is a T-5 case with transfer case extension housing/shaft, but it is even more rare than the V-6 4wd M5R2. It's most commonly found in mid 80's Heep CJ's coupled to a Dana 300.
Note 2: The T-5 gear set that is rated for v-8s has a 2.95:1 1st. The gear set in the Heep T-5 has a 4.03:1 1st and isn't known to hold up well behind the I-4 in Heeps. So, again, you would be cross pollinating a V-8 transmission with 4x4 transmission. Then, you need to fabricate a hydraulic slave cylinder for the T-5. (Or if you are real glutton for punishment design a cable clutch for the Ranger). And you are left with a mediocre 1st gear for wheeling. (I suppose it would be OK for a mall crawler).
Clear as mud now?
*I'm probably missing a few factory Windsor V-8 combinations, but those are the common ones.
lvwill
143
Las Vegas Nv.
2.3 EcoBoost
2.3 Ecoboost
That's exactly what I was talking about. Just in a hurry
17,982
SW Iowa
Its ok, I think both first and reverse are a little on the fast side. In low range it is a beautiful thing on a trail though.
The 4.2 does have metric bellhousing bolts. Like 12mm. A 302 uses 1/2" bellhousing bolts so you do have to drill the holes out to so the 302 bolts will fit.
I used R1 clutch hydraulics (all of it) and the clutch kit for a '96 F-150. If you use a '80 or older 302 you could use the clutch stuff for a'96 F-250 to get the right balance. You also need the starter (which will need a little wiring change) and engine separator plate from a Windsor V8 R2. The starter hole is smaller for the V6 (and other transmissions too) I discovered this after I had it put together and went to put the starter in it, I dremelled it out and it works but it was a PITA.
don4331
1,356
Calgary, AB
5.3
Thx, I forgot about the reaming out of the bellhousing bolt holes and the engine separator plate (Windsor V8 R2 plates being super rare...) I put everything together once* before it went into truck so caught these when they were somewhat convenient to modify.
*Well more like 4 or 5 times.
I need 1st to be low enough to get the load moving - a 2.95:1 1st doesn't cut it. And you can't shift on fly from low range to high.
17,982
SW Iowa
I compared the plate between the engine and the trans, never thought about the starter being different diameter. I knew it was different than the old style one I had with my C5 though, and it is just a hair different. And no you can't cram it in the hole either...
M5ODR2 first isn't bad, I was just saying it could be deeper.
