V8 Manual Steering conversion
Dan B.
January 2012 STOTM Winner
MTOTM Winner
22
Armagh, PA
387 Windsor
I want to swap from power to manual steering on my 1985 351W 2wd Ranger. I'm now running the acc'y drive from my donor car, a 1978 LTD2. The pump is huge!! It's a twin V-belt...one belt drives the alt while the other runs the PS and water pump. I need one belt to drive the alt and water pump but the current pulley set up won't let this happen.
I want to do the conversion to clean up the engine bay, drop some weight and get back a few strangled ponies!
Is there a good donor acc'y drive that will work on the 351W? Or can you recommend a good aftermarket system that will only run the water pump and alt from the crank?
I'm also looking for the manual box if anyone has one to sell.
red85
7
Kitchener, Ontario, CANADA
306 ci
I used a serp drive from a 90 Bronco. I made a bracket with an idler pulley and I use an XS2E 8620 EB Motorcraft belt. You will also have to swap your water pump for a reverse rotation model if you go to a serpentine setup. Most of the 302 serp drives use a reverse rotation water pump. You may also want to check out Zoops and March for complete setups. Initially, I looksed at them, but $$$ wouldn't permit. I figured that since all I had to run was a water pump and an alternator that I could modify something to work.
red85
7
306 ci
Here's a pic of my serp setup
baddad457
18
Opelousas La.
The early 70's 351W's and Cleveland's waterpump and crank pulleys are what you want (same for both) If you can't find these, I have two sets of extras available--cheap.
281Ranger
September STOTM Winner
MTOTM Winner
4
Wanamingo, MN
4.6 dohc
Check out www.car-part.com for a steering box. Have it sort by distance to check the salvage yards near you.
Chic N Stew
Richmond, VA
2.9ltr
I have manual steering and manual brakes in my 82 s10 350, if you need any info you can post or send me a PM
Dan B.
MTOTM Winner
22
Armagh, PA
387 Windsor
...and this will drive the water pump and alt??
How much? PM me if you do not want to post on the thread.
supermonkey
I have a box you can have for the price of shipping
Dan B.
MTOTM Winner
22
Armagh, PA
387 Windsor
e-mail sent
