Using low and high beam headlights at same time
Ocrap
Sumner, WA
Have any of you performed the upgrade covered by the Ranger Station "High Beam upgrade" found tin the TRS technical section? My 2011 Ranger uses the 9007/HB5 bulb for headlights. This sounds like an easy upgrade to do that will really help with motoring through rough places on dark nights but I am worried about excessive heat quickly destroying the 9007 lamp.
I might do this on just one side to test it out.
All that heat isn't great for the lens either.
If you really want more light for off-road, go buy more lights.
Captain Ledd
39
Michigan
302, 2.3
If you're not making mistakes, you're not learning.
This is best done with vehicles that have separate lamp housings for Hi and Low beam. A acquaintance I knew from college had the bright (see what I did there?) idea to run some super-duper bright bulb he rigged into his Ranger, and yes, he DID melt his housings.
I'm with adsm08, consider this a second vote for another set of lights.
SenorNoob
575
Middle Tennessee
1.5" Front + 4" Rear
245-70-R16
Ocrap
Sumner, WA
melting the lenses
Thank you for the good advice. Melting the outer lens would be a bad thing.
I have PIAA5190s mounted in the front bumper and the results have been disappointing. With a winch occupying the center of the bumper I had made there is not much room for other lights. I may get one of the led strips to fit above the winch. I have been putting that off due to fear that someone will steel it.
It won't melt it, but it will make it cloud up a lot faster.
Bronco638
5
Chicago-land
You might want to consider some LEDs as auxiliary lights. They're low draw and can be quite bright (i.e. not street legal). I can point you in the direction of some that I use on my motorcycle (see signature), if you're interested.
