Turn signals not working
92ranger4x4
British Columbia
Ford ranger
My turn signals are not working and neither are the indicators on the dash. The fuse blows as soon as the ignition is turned on. I have replaced the turn signal switch and the drl module, I had a look at the lights in all 4 corners and didn’t see any bare wires, are there any other common places for shorting out?
8,374
Welcome to TRS :)
Assuming 1992 Ranger
Turn on 4-way flashers, if they work then turn signal wiring is OK
What is the number of the fuse?
Cab fuse box diagram below, 1991/92 is the same
If its fuse #5 then it powers Turn signals, but also reverse lights and Master's brake fluid level sensor
Unplug the Brake fluid sensor, see if fuse blows
Unplug the Reverse light switch, its on the transmission, manual or automatic matters
Unplug the Flasher, the round unit in fuse box
92ranger4x4
British Columbia
Ford ranger
Welcome to TRS :)
Welcome to TRS :)
Thanks a ton for the info! Unplugged the sensor on the tranni and now they work
8,374
Good stuff :)
Could be a bad reverse light switch or a shorted wire or bulb at the rear
Test with OHM meter is best
92ranger4x4
British Columbia
Ford ranger
Good stuff :)
Great thanks a lot!
