turn signal/reverse fuse blows when i hit the brakes...
mattc113
Okc, Ok
5.7
Solid Axle Swap 4x4
8"
37"
anybody else ever have this problem? 89 bII
country0001
14
Stillwater, OK
Ford,Ford
4.0,5.0
You probably have an exposed wire somewhere.
mattc113
Okc, Ok
5.7
Solid Axle Swap 4x4
8"
37"
...i hate exsposed wires!
Check your brake lights. The brake bulbs and rear signal bulbs are the same bulbs. You probably have a burnt brake filament that is resting across another filament.
