ttb35 gears
vince87ranger
woodland, IN
one of my buddies has a set of 4.56 rear gears for his jeep days that he gave me. will they fit in a ttb35?
Hahnsb2
36
Battle Ground WA
Ford-Dodge
4.0-5.2 Turbo
feellnfroggy
28
Knoxville, TN
Serious? WHat kinda jeep is it. If it is a wrangler with the Dana35 for the jeep they 'should' fit just fine, Hahn you have a d35 with 4.56's, why would you post that they wont work?
Hahnsb2
36
Battle Ground WA
Ford-Dodge
4.0-5.2 Turbo
Jeep D35=Low pinion. TTB D35=High pinion.
Explorin94
Law Enforcement
Firefighter
EMT / Paramedic
19
Farmington Il.
Jeep is a standard cut and the TTB 35 is reverse cut.
mhughes165
9
302
PHYSICALLY they can work, but alot of people are against running on the coast side of the gear. if its for a wheeler i say try it, free is for me as i always say, whats the worst that can happen, u have to order the right gears?
Hahnsb2
36
Battle Ground WA
Ford-Dodge
4.0-5.2 Turbo
No they won't physically work.
mhughes165
9
302
have u tried this? i have....it bolted right in, i had to get a different pinion bearing and crush sleeve and used the heep detroit he had, i know it worked.....idk for how long, i no longer speak to the person whose truck it was done it....
and wouldnt suggest it for road use ever
Hahnsb2
36
Battle Ground WA
Ford-Dodge
4.0-5.2 Turbo
The Low pinion gears will not physically mesh in a high pinion configuration. You can take a ring and pinion, put them on the work bench and try it, it doesn't work.
It was either an IFS D35 or the correct gears.
vince87ranger
woodland, IN
this is basically what i was wondering. i am not worried at all against running on the coast side as my truck is only a 4cyl and not wheeled as hard as say a 4.0 or 5.0 would be. but if they wont physically mesh i guess im up s**t creek on this idea.
