TTB axle retaining "C" clip
Blackdog
Zillah Wa.
Dana 28 and 35's use a "C" clip to secure the drivers front axle. I wasted mine today during the reassembly. Where can I find another? I ordered some from Ford but I need them now, Will a generic clip work?
dusto2
scv ca
do you mean the passenger axle shaft if thats the case why not eliminate it
Jspafford
Logan Andrew Feb 17, 2012
15
Lancaster, Ohio
Chevy 3500HD
6.6L
5"
You mean the one behind the hubs or the one inside the differential.
The one behind the hubs can be found at almost any junkyard. So can the other, but it a lot more involved to get to.
Blackdog
Zillah Wa.
The one inside the diff.
Sasquatch_Ryda
Forum Staff - Retired
108
Terrace, BC, Canada
Solid Axle Swap 4x4
40s
Alot of guys are running that here, just think how easy replacing that center u joint will be!
Hahnsb2
36
Battle Ground WA
Ford-Dodge
4.0-5.2 Turbo
Lots of people have done it, don't want to pull the pig to remove the clip if you bust that shaft do ya?
Sunk
125
Everett, WA
3.5 Eco
I was kinda wondering about this myself when the C-clip flew across the room when I was taking apart my D35 earlier....
I'll be doing that when I get the Lock-Right up front in mine. Seems like if you tack the backside of the cap, you should be good to go.
Todd
HCT
12
Troll land
BIITR
Solid Axle Swap 4x4
If you have alot of flex the internal spring does not work well. Run and external spring and everything will be fine.
rickcdewitt
5
nor-cal
4-0 swap
maybe trs fab can be convinced to offer those external springs for the d28 and d35 eliminator?
4x4junkie
583
So. Calif (SFV)
Bronco II
2.9L V6
35x12.50R15
I use this on mine also (hose clamps used to secure the boot also secure the spring).
Spring needs to be 2.5-3" long, 1-3/8" I.D., and rated around 20-30 lbs-in.
As was mentioned, internal springs leave little room in there for the shaft to move when the suspension droops (which can bust the dust cap out of the axle yoke).
Sunk
125
Everett, WA
3.5 Eco
I like Junkie's idea a little better, maybe I'll do that instead...
DangerRanger
Columbus, In
I used the external spring like Junkie, seems to work just fine. Just take time and use some sense to get the tension correct so you don't have excessive pressure on anything.
No members online now.
