Truck won’t drive after spindle install
NCHammer
Knoxville, TN
Ford Ranger XLT
I finished installing the 4” spindles, I did trim the LCA so they fit properly. Now the truck doesn’t seem to wanna move. The tie rod end looks like it’s touching the inside of the wheel but I’m not sure if that’s what’s causing the issue. I turn the truck on, take park brake off, put it in first gear and it’s too difficult to move, I don’t wanna break anything if I’m applying pressure somewhere that shouldn’t be. Need help, thanks
dvdswan
2,909
Seattle, WA
Ranger XLT 2WD
Jack up the front end and see if the front tires turn. If not, then something is keeping the tire from spinning. From the TRE or bearings being too tight.
NCHammer
Knoxville, TN
Ford Ranger XLT
I loosened the lug nuts a little and there’s slight movement. I also noticed my wheel weights scrape the tie rod
NCHammer
Knoxville, TN
Ford Ranger XLT
When I remove the tire and caliper the rotor has free movement
ericbphoto
Overlander in development
TRS 25th Anniversary
16,784
Wellford, SC
3.0L
6"
Does it lock up when you put the caliper back on? Is it both front wheels or just one?
NCHammer
Knoxville, TN
Ford Ranger XLT
Seems like both. A little difficult when the caliper goes back on. The description of the spindle said it fits with 15” or higher wheels, mine are 15, but the spindle and the tie rod are touching the wheel, so I got 4 new tires and 16” wheels a week earlier than expected
Rowdy Fitzgerald
Hog hunter
Firefighter
EMT / Paramedic
372
Nevada
5.0,4.0
Solid Axle Swap 4x4
6”
Sounds like the rim is hitting the TRE and not allowing the wheel to spin.
Rowdy Fitzgerald
Hog hunter
Firefighter
EMT / Paramedic
372
Nevada
5.0,4.0
Solid Axle Swap 4x4
6”
She looks pretty damn good bud!
