While driving in town today I had my '89 2.3l 5 speed repeatedly die on me. After noticing that it hapenned with clutch out and while either slowing down or stopping I decided to monitor the tachometer during those periods. I found that it would start out at about 1700rpm and then as I depressed the clutch it would rapidly drop to 500rpm and then slowly drop down too 250rpm and die. I could then depress the clutch again and crank the engine and it would start right back up but only idle at 600-700rpm with the needle jittering about, which is not normal for this truck. If I rev the engine up to aroung 2800rpm before I slow down she won't stall but will idle at 400-500rpm. I haven't done anything to the truck recently and she just started having this problem a few hours ago. Any help would be much appreciated as I don't have the time or resources to replace anything but what absolutely needs to be replaced.
