Trouble replacing water pump in '02 3.0lt Ranger
kbanes
I am trying to remove the old pump. I have the radiator out, as well as the shroud. I can't get the fan/fan clutch shaft separated from the water pump shaft. My shop manual shows a big honking wrench (they call it a fan pulley holding wrench) hold the pulley steady while another wrench loosens the fan shaft.
My problem is that there is no flat on the pulley or water pump shaft for me to get the fan pulley holding wrench on. The pulley is perfectly round, and the water pump shaft is round. No flats.
I have the fan pulley holding wrench that I checked out from my outparts store.
I tried a strap wrench on the pulley, but it won't hold.
Any idea on what I am doing wrong?
Thanks for your time.
kbanes
coffee
Buena Vista, Ga.
It can be a big pain but you can do it. Those strap wrenches can slip. I used a piece of my old belt with some large vise grips. Also, the fan has reverse threads. In otherwords, righty loosey, lefty tighty. Good luck.
Southern3.0
New Port Nowhere FL
'96
2.3, what a turd...
The fan pulley wrench goes around the 4 bolts that hold the pulley to the water pump.
kbanes
On my truck the 4 bolts that hold the pulley to the water pump are inside the pulley. You can't get the wrench on them. I am going to try to install some studs coming in from the back side and see if I can use the wrench that way.
kbanes
Missed that while I did search yesterday. I never searched on fan clutch.
Anyway, I had success by removing the 4 bolts in side the pulley, screwing 2 studs into 2 of the four bolt holes from the back side of the pulley, and holding the pulley tight with the fan pulley holding wrench that I rented from the auto parts store.
I still couldn't break the fan shaft loose (I actually rounded off one of the flats trying to break it with a crescent wrench). A quick trip to Sears to get a 22mm open end wrench, along with a torch placed on the fan shaft got it loose pretty quick.
Thanks to everyone that offered solutions. I appreciate it.
Kevin Banes
sbsumerix
Pullman, MI
Mazda
3.0L
yeah do it in the parking lot with limited tools that was a fun day.
