Torx bit size?
Drummadude
7
Lexington KY
I am disassembling the dash on my 1987 Ranger and I am removing the harnesses on the steering column (so I can remove the steering shaft to pull the cab off the frame), but I am not finding a torx bit size in my set to remove the main ignition harness, anyone know what gives?
tw205
Bronco II Rancher.
986
Bronson Michigan
Ford Bronco II
2.8 V6
2.8
6” skyjacker 2” body
33x12.5
You need a smaller torx than what you have or are they security/tamper poof torx?
tw205
Bronco II Rancher.
986
Bronson Michigan
Ford Bronco II
2.8 V6
2.8
33x12.5
I see them listed as small as T2 in single digit increments thru T10 then in increments of 5. I’ve never seen a T1 but I cant believe they would skip that number and just start at 2. 😜 I’ve never seen a security type smaller than a 7 but I know I ain’t seen everything.
Drummadude
7
Lexington KY
It's like it's an in between size. My Torx bits are either too big or too small. I tried to do a Google search but didn't dee anything in a cursory scan, that's why I posted here as there are more knowledgeable folks on this site.
tw205
Bronco II Rancher.
986
Bronson Michigan
Ford Bronco II
2.8 V6
2.8
33x12.5
What sizes is it between? Have you tried using an Allen wrench instead.
alwaysFlOoReD
5,172
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
Sometimes Allen keys will work.
Also I think there is a t-27.
tw205
Bronco II Rancher.
986
Bronson Michigan
Ford Bronco II
2.8 V6
2.8
33x12.5
Drummadude
7
Lexington KY
Thank you all, I will try that today.
ericbphoto
Overlander in development
TRS 25th Anniversary
16,785
Wellford, SC
6"
Might want to check out this thread
Roert42
5,079
Kintersville, PA
Ranger XLT
4.0 SOHC
Here is a list of all the different Torx sizes, maybe you can measure with a caliper or something and use this chart to determine the right size torx.
https://www.wihatools.com/torx-sizes
