Torquing Head Bolts/Other
Twister
17
Omaha, Ne
Duh
5.0L, 2.9L
Ok, so what size are the bolts for the exhaust manifolds? I broke everyone so i need to buy new ones from the hardware store.
Also do i need to put rtv on the bolts for the lower and upper intake manifolds?
They are an 8x1.25 thread. Don't remember how long. Just get the right thread to stick 1/4" out of the manifold.
I wouldn't RTV the manifold bolts. I usually spray some of that orange copper crap on the upper gasket though.
Twister
17
Omaha, Ne
Duh
5.0L, 2.9L
Orange cooper crap?
85_Ranger4x4
17,907
SW Iowa
Orange cooper crap?
High temp anti-seize/never-seize... whatever you want to call it.
It appears pretty the same as the normal silver stuff, only copper.
Not, not the anti-seize. The gasket sealer.
Twister
17
Omaha, Ne
Duh
5.0L, 2.9L
Well after getting it about 90% put back toghter, i was installing the a/c and alt bracket, when i noticed 2 of the 4 alt bracket bolts dont fit. The bolts that go into the heads are to small for the hole :sad::annoyed:. It appears they made the 2 bolts holes the same size as the 2 bolts that bolt into the block. So what size are the bolts that hold on the alt bracket that go into the block?
There are 2 large ones and 2 small ones, i need to know the size of the large ones.
85_Ranger4x4
17,907
SW Iowa
Dur, I missed the gasket part... I was stuck on the bolts.
I put that on the exhaust manifold gasket and the copper anti-seize on my header bolts. The intake gets the red "Hi-Tack" spray stuff.
There are a million different ways to do it, that is how I did it. They always use the red stuff for intakes at work and the header instructions said to use the copper stuff on the exhaust gaskets. I was scared of dealing with the little exhuast manifold/header bolts when they got some age on them so I figured I would try the copper anti-seize.
Twister
17
Omaha, Ne
Duh
5.0L, 2.9L
Well i am getting close to getting my truck all put back together, but i have run into a misc sensor.
Here is a pic
Also got a question about the alternator bracket, i figured out the bolt size of the larger bolts, its 10x1.25. With putting in the new bigger bolt i lose the ability to put int he bolt which goes into the exhaust port. So is it safe to run the alternator with only 2 bolts in the bracket?
Sensor is for EGR flow.
Twister
17
Omaha, Ne
Duh
5.0L, 2.9L
Twister
17
Omaha, Ne
Duh
5.0L, 2.9L
Figured it out, it bolts on top of the throttle linkage.
