Topper boot.
vigness
37
Princeton, KS
Ford Ranger FX4
Have a situation where I may want or even need to put a boot between my cab and topper. This is an above the cab topper with an 8" high nose that sicks out over the Ranger super cab a little over two feet.
To the best of my knowledge I have three choices. The inflatable doughnut between the two sliding windows. Works, but not great for getting heat / AC between them. Then comes the two boots. A single side that presses up against the cab window, still only the small slider on the truck and not much of an improvement over the doughnut. And finally the full boot. Both topper and cab windows out with the boot all the way around.
The last is the most expensive, but to my mind also the most desirable for heat, AC , and bodies to get through. Can anbybody talk to the plus and minus of the full boot? On the other end, can the doughnut be made to work as long as you don't expect my fat ass to crawl through that skinny window?
bobbywalter
Ugly Truck of Month
4,680
woodhaven mi
FORD mostly
BIGGER
sawzall?
I would just run another heater.
sgtsandman
Aircraft Fuel Tank Diver
U.S. Military - Active
Ham Radio Operator
TRS 25th Anniversary
12,875
Aliquippa, PA
Ranger XLT/FX4
4.0 SOHC/2.3 Ecoboost
Pre-2008 lift/Stock
31X10.5R15/265/65R17
They make the window small on purpose to prevent people from breaking into your vehicle through the rear window slider. For rear vision, a full boot would be best if you want to leave it on all the time. If only part time, an inflatable might be the best compromise.
Like Bobby said, running a separate heater in the bed is probably going to be the most effective solution.
Uncle Gump
Token Old Guy
13,619
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
Full boot would also require a pretty high level of commitment.
If you want to use the truck without the camper... you're putting glass back in.
vigness
37
Princeton, KS
Ford Ranger FX4
This would be a full time install. It's a special topper for a specific purpose. Onlyt time it sould some off would be to trandfer to a newer Ranger,
bobbywalter
Ugly Truck of Month
4,680
woodhaven mi
FORD mostly
BIGGER
sawzall?
I drove my truck for nearly a decade with no back widow
bobbywalter
Ugly Truck of Month
4,680
woodhaven mi
FORD mostly
BIGGER
sawzall?
In that case....cut it right out for easy access and run a heater and ac back there
sgtsandman
Ham Radio Operator
12,875
Aliquippa, PA
Ranger XLT/FX4
Pre-2008 lift/Stock
Even with removing the rear window, you might want to setup a separate heating system back there. Especially if it's going to be a camping setup where you will be in there with the engine off. If it's not going to be a camping thing, then maybe a remote heater that taps into the coolant system of the truck. No idea what one of those would cost and you would need to run hoses and electric back there for the fan to blow the heat out of the unit. Bed caps are not air tight and there won't be any insulation back there. So, I'm not confident the stock heater will be enough.
scotts90ranger
4,541
Dayton Oregon
2.3 Turbo
A boat heater would be the way to go there, heater core and fan all in one...
snoranger
Professional money waster
ASE Certified Tech
13,742
Jackson, NJ
'79,'94,'02,'23
All Fords
2.3 EcoBoost
It’s time for a junkyard run... go find a rear HVAC box from a van or bigger SUV.
vigness
37
Princeton, KS
Ford Ranger FX4
I'm leaning toward the full boot and was leery of unknown problems. So far I haven't heard of any real problems, just some logistics to overcome. A good sign for me.
