tire grooving ???
tmaxxman
PA
2.9L
got a ??? can i get away with grooving this tires just for offroad uses they are right are the tread bars.and yes i know there dry rotted and if i can what would be the best way to do it try to stay in the tread pattern or what cut across the tread :icon_confused: what would be the best pattern to go with
[/IMG]
[/IMG]
06RangerXLT
54
Georgetown Ontario
im gonna say no, but i bet its possible, i just wouldnt.
tmaxxman
PA
2.9L
anyone else ???
kevinsranger
edison nj
FORD
i don't think there's any meat to put groove's into on those honestly, i mean i've been wrong before, but how deep of grooves do you think is possibly to cut onto those?
06RangerXLT
54
Georgetown Ontario
yea, think your better off getting cheap used tires.
wrecking-crew
25
dirty jersey
06 chevy
88 ranger
6 cylinders
Try finding some better tires. Those are a bit too low to groove.
TimV
4
Maryland
3.0L
If you are using them for offroad only, groove them up. The worst that could happen is you cut too far and ruin an already bad tire, or you get a flat on the trail. More than likely though, you will get a good bit more use out of them. Do not groove them if you plan on using them onroad at all. That's an accident waiting to happen.
I'm not sure it will work. Normal tires don't have enough room from the bottom of the treads to the cords.
Also, I think it only works right with straight treaded tires.
alwaysFlOoReD
5,100
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
x2
Richard
tmaxxman
PA
2.9L
well i did it i guess i will see how it works
[/IMG]
[/IMG]
wahlstrom1
J-man HD Mech
2011 Truck of The Year
Forum Staff - Retired
21
Edmonton Alberta
Usually I don't bother grooving normal tires as the carcass doesn't have enough meat to justify the effort. I have split up lugs and changed tread patterns plenty, but I usually save the carcass grooving for the michelin military tire, XML/XZL/XL etc. which you can take 1/4-3/8" out of without worry.
AgPete139
09/2014 OTOTM Winner
61
Houston, TX
4.0L OHV
Solid Axle Swap 4x4
~9"
35"x12.50"x17"
*shrugs* Meh, I dont see the harm if it is ONLY off road in the dirt, and not speeding. Have at it.
It doesnt look like you took that much out of it though.
