Tire Clearance
gettle03FX4LevelII
Harrisburg PA
Ranger FX4 Leve
I have a 2003 fx4 level II with 31X 10.50 will i have issues with tire rub if i put a 3 in body lift on and up size to 33X12.50
Wicked_Sludge
43
Westport, WA
3-point-GO
they should fit fine with minor or no rubbing.
JohnnyO
Moderator Emeritus
Forum Staff - Retired
2,860
Pittsburgh, PA
2.3 EcoBoost
1.5"
No, however your stock rims are 15x7 which is really too narrow for a 12.50 tire.
A 15x8 rim with 3.75" backspace or 15x10 with around 4.25" backspace would work fine.
danger03ranger
Birmingham, AL
i have a 03 ranger and i put 32x 10.5 on it, with no lift. i had to take my mud flaps off because they were the only thing that rubbed. i think the fx4 II sits a little higher too.
gw33gp
Ham Radio Operator
538
Costa Mesa, CA
4.0 SOHC
33"
I don't think the FX4 II sits any higher than standard 4WD. Although I have 32x11.5 tires on mine and there is no rub with the mud flaps on. I did crank the torsion bars up about 1.5" and maybe that was enough to help it clear.
BTW, I have never come across any 32x10.5 tires. Was that a typo or do you have a brand I never heard off?
Hahnsb2
36
Battle Ground WA
Ford-Dodge
4.0-5.2 Turbo
FWIW I have seen that size in TSL's before...
PARKINGLOT
St. Thomas, ON
Jeep
5.2
I've seen a stock Level II run 33x10.5's stock....
LittleBigFoot
5
Denver Colorado
Mostly Ford.
Building a 408w
You can always crank your torsion bars and shackle or block the rear.
gettle03FX4LevelII
Harrisburg PA
Ranger FX4 Leve
if i want to go the cheap way could i shackle the rear get lift springs for the front and do it that way.. ohh and will i need a drop pitman arm for the steering angle for the front right
JohnnyO
Moderator Emeritus
2,860
Pittsburgh, PA
2.3 EcoBoost
1.5"
Really, just turning the torsion bars up you can fit a narrow 33, like a BFG 33x10.50-15 or 285/75-16.
Nehring13
Waterford, Wisconsin
torsion bars
how far can i crank the torsion bars on my 98 ranger? i know i can block the rear, but i wasnt sure how far i cpould crank the torsion bars, and i didnt want a rake job going on. so just how far can i crank them before i get reverse camber? i have them set to be equal height as the back and i have 31x10.5 mudders on it.
Thanks,
~Mike
JohnnyO
Moderator Emeritus
2,860
Pittsburgh, PA
2.3 EcoBoost
1.5"
1.5" and level with the back is as high as you should turn the torsion bars.
gettle03FX4LevelII
Harrisburg PA
Ranger FX4 Leve
you said the 15X7 are to narrow for a 12.5 tire, what are the consequentness if i run it on the rims i have. I can imagine i wont be able to air down which could cause the tire to come off the rim which is really not a concern since i wont be doing any rock crawling. what else besides that could i possibly have issues with?
JohnnyO
Moderator Emeritus
2,860
Pittsburgh, PA
2.3 EcoBoost
1.5"
The tire will wear more in the middle from being squeezed onto too narrow a rim. You can lower the pressure to compensate, but maybe not enough, plus it will handle like crap and probably wander all over the road from the low air. Also the factory wheels likely have too much backspace for 12.50's and they will rub on the inside.
I mean, you can get aluminum 15x8's (with 3.75" backspace) for about $100 each and steel for about half that.
