Tractor Dan
- Dec 29, 2008
- 1
- Near Lima, Ohio
- Ford
- Engine Size
- 3.0
Back probed the tps sensor today. Followed the article and the wiring diagram for my truck. Here is where things got interesting. With the throttle fully closed, i verified by looking at the butterfly. My meter was reading 4.16V fully closed. As i depressed the throttle linkage out at the engine it went down to .5 volts or so floated between .51 to .53 volts. From what i understand it should be the exact opposite of this. Also i checked the signal wire by back probing that and grounding my meter to the block and got signal voltage of 5v.
Background on the vehicle. 94 Ranger 3.0L. Engine was recently swapped in from a yard so who knows what the sensor has been exposed to. I want to investigate all options before throwing a $50+ sensor. I don't think it's wiring as i'm having no other issues with anything else. I'm going to look at wiring diagrams to see what else may share a common power or ground.
