Think I found my problem guys!!!
knucksfirst
Ontario, Canada
Mazda
Well was fooling around today trying to figure out why the truck isnt running properly. Theres no real way to explain it in words I have a video here to show. Ill also post some pics in a few mins. Heres the link to my video!
http://www.youtube.com/watch?v=MayxJNfA7R0
t0x1k
9
Somerdale, NJ
3.slo
Yep, that looks like a problem to me.
'99 EB Explorer
55
Sudbury, Ontario, Canada
That would be your EGR valve, wouldn't it? Yeah...vehicles don't like running properly when vaccum lines aren't plugged where they're supposed to be
Bad things happen when the EGR valve falls off the intake dude. Bad things.
mywhip
Ohio
2.3
I was hoping a cat, or squirrel was involved with this..
Ranger Dave (B25)
134
RFD/BNA/PHT
'10
Don't vote Democrat.
That's the new FLEGR valve.
Floppy-EGR. Only found on certain models. Like yours, apparently...
knucksfirst
Ontario, Canada
Mazda
Alright I just took a quick look and well the one I got to relplace it is kinda different, the top hole nozzel is in the middle and mine was on the side.. it still hooks up but does it work differently?? here is a picture
THEY are the same size its just the angle I took the picture on.. im just worried because the hole on the top is in a different place so maybe it doesnt work the same inside?
If its good then im ready to put her on and she if she runs! :yahoo:
knucksfirst
Ontario, Canada
Mazda
If it dont hurt and the truck runs fine then ill be a happy camper, but I dont wanna waste my time putting it on if its gonna malfuntion.
scotts90ranger
4,372
Dayton Oregon
2.3 Turbo
it's all above the diaphragm, shouldn't change anything
kimcrwbr1
46
maplevalley WA
2.8l
All that matters is if it will hold vacuum pressure. Also check that the valve works good also. With no vacuum it should be all the way closed blow on both sides so you know it seals in both directions that way your testing the valve seal on top also. if you have or can get a hand vacuum pump then you can check that it opens and holds pressure in the diaphram. Make sure you put new gaskets made for the high temps or it will develop a vacuum leak and if it was me I would start looking for a new egr because there is not telling when a used one will fail and it is never at the right time.
knucksfirst
Ontario, Canada
Mazda
This one came off a ranger with only 104,000kms. I appreciate the information fellas and will hook it up tommorow and see how my truck runs. Thanks again :beer:
knucksfirst
Ontario, Canada
Mazda
If I still have a problem then maybe ill go new :) But who knows maybe I still have another existing problem. :annoyed:
