Well here's the 95% finished piece. I have a small piece to add for the upper section to close it in beside the door lock and I have to cut some aluminium checker plate for an inner panel but other than that, she's almost done. Keep in mind the pics are with the door loosely bolted to the stock BII hinges. Oh I need to get rid of the "RANGER" decal and pin stripe too, it ain't no stinkin Ranger!! lol
When I sit in the drivers seat and lean out the door with my but still planted in the seat, I get a way better look at what's coming up in front of the drivers tire, if I lean a little further I can see under the front diff from behind the front tire, radius arm and all this with my ass still planted firmly in the seat. A quick look rearward from this view and I can see under the drivers side rear diff as well as what I am about to back over with the drivers rear tire.
These half doors ROCK!!!!! I love em already and I haven't even tried them while the Bronco's moving!!!!!! #rockon
Rearward angle view, shows off my sexy blue dash, ha ha, the door provides a wicked better view from inside, the top plate is right below my elbow for a perfect arm rest height. Actually when I decided on a cut line, the factory arm rest was my choice, this way the door is a perfect arm rest, I may even add some foam-pad and vinyl to the top plate just so I'm not leaning on hard steel. #popcorn
Front angle view, she looks sexy!! Turns out my door cut line matches up with my fender cut lines, fluke tho, wasn't planed at all, but really works and blends well I think.
Opened up easily, the Explorer latch and handle work like a charm, easily accessible from outside the door and the door pops open without pulling on it too. I tightened up 2 of the 4 door hinge bolts and the door swing shut perfectly, no banging clunking or rattling, she shuts with a clean click fully shut, just like the stock doors. The door needs some tweaking as the window portion or upper frame is bent outwards from the roof seal, has about a 1" gap when closed. So I'll need to bend it back inline a bit for a cleaner look if anything.
