thank you to all on oil pressure but...
mailmanj
Mississippi
2003 ranger edge 4x4 4.0
i would not of made it this far without the wisdom shared here. i regularly change the oil and add a half quart of lucas every change.
i was on my way to work the other day when i noticed my oil pressure bottom out. i noticed if i gave it a little gas the gauge would go back to normal. i didnt hear any strange sounds so i continued with my day. i use my truck on a 95 mile mail route with gravel roads being about half of my daily drive. i didnt notice any sound that would be alarming at any point. i got home and read through the forums here and saw that almost 100% of the time the first suggestion was " install an after market gauge preferably mechanical".
so i did and what i noticed is that on cold start up the gauge says 60psi and when it warms up it drops to about 30-40psi. at this point im assuming the switch on the side of the block was bad. but this seems really high. is the new gauge broken? the other concern is now my check gauges light is on. i remember someone referenced a t but is there a specific part used or just head to lowes and search for an afternoon?
alwaysFlOoReD
5,174
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
It would probably help if we knew what engine. I'm not super knowledgable but those pressures seem fine, maybe somewhat high possibly because of the Lucas. Is the Lucas you mention have a viscosity like honey? I think the 2003 uses 5w20 so adding lucas would change that quite a bit, probably not hurting anything other than mileage.
mailmanj
Mississippi
its a 4.0 i have been using 5w 30 since i got the truck. purchased with 60k it now has 275k miles on it. i change it every 3-4k or about every month and a half.
holyford86
Some guy with a problem
656
Plattsburgh, NY
many
33x12.50R15
60psi at cold start is fine, spec is 40-60 psi at 2000 rpm engine fully warmed.
3,614
Yeah, your numbers sound ok to me. It should be more like 5 to 10 at idle, fully warm.
The tee in question should be a 1/4" NPT IIRC. Really the easy way to do it is to take the old sending unit to the store and use it for comparison. If you find someone who works there it shouldn't take more than a few minutes to have what you are after.
