Teach me about fuel trims and such...
Dirtman
13,328
41N 75W
It's up there.
It's down there.
Round.
I poop in the furnace.
More than once I've worked on a vehicle where there is a CEL and before even scanning it I popped the hood to find a aftermarket cold air intake with no provision for the fresh air side of the PVC system to connect so the owner just left it off. Put a nipple on the intake tube, hook up the line and no more CEL.
bobbywalter
TRS Technical Staff
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
Yeah Gump
Dirtball is right.
Dirtman
13,328
41N 75W
It's up there.
It's down there.
Round.
Hey! I'm a man! Not a ball!
Uncle Gump
Token Old Guy
TRS 25th Anniversary
13,529
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
Right about what? That it will set a code?
Uncle Gump
Token Old Guy
13,529
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
Looks like I may have to eat my words on this one...
I was confused because the metered vacuum leak from the PCV doesn't change volume if the fresh air tube is connected or not. What changes is this fresh is now not metered with the fresh air tube disconnected. When you bypass unmetered air past the throttle plate... vacuum leak.
I realize the error in my ways.... sorry dirtball.
Bobby... you always make me think harder.
G8orFord
803
FL
4.0 SOHC S/C
Just the right size to touch the ground.
Makes sense, I guess. Thanks for the replies.
