Tallest Lift
montazch
Morgantown, WV
Sold
Just curious. Who has the tallest lift on this forum and what all did you do to make it?
I'm wanting to find some different approaches. I'm looking at 44s, with Dana 80's front and rear cut up. Linked suspensions with coils front and rear.
I have no problems fabricating but I'm wondering what works and doesn't break all the time.
Thanks!
:icon_welder:
BabyBronco89
GR Michigan
95' 4.0 OHV
it might be a little helpful to know what your intentions are for the rig, strictly trails, mud bogger, rock climber, dunes ext.
Just remember the taller you go the higher your COG, i know a lot of guys have stuck 44s under their rigs with some cutting a 5inch suspension lift and a few inches of body lift. anythings possible. i have approx 5.5 inch suspension lift on my b2 with full size axles and i could probably fit 44s if i cut my fenders.
montazch
Morgantown, WV
Sold
I hate to say this but she will be a show truck. She's been a show n go truck for a while now and she deserves better. She had a 9 inch total lift and sported 35s under her for quite some time.
My intentions are no cutting of the body. As much wheel travel as possible. Strong and dependable. Of course 44s, and coil-overs at all four corners. A long travel 4-6 link in the front and rear. Dana 80's front and rear, slightly cut down with custom axles. In other words, the suspension and axles will be completely custom made.
Those are the big ticket items.
6.2
11
Rural Manitoba, Canada
Wait, so strictly a show truck? Then toss a dana 30 up front and don't waste Dana 80's. Leave those to people who will actually use them.
montazch
Morgantown, WV
Sold
To me it will still be a show and go truck. If I have the notion of going off road, then I'll have the ability to do so.
I actually want it to participate it in parades and travel from my home to shows nearby, soooo. If I wasn't going to do that then why not stick with my current build?
44's would snap Dana 30's like a toothpick. Same with a Ford 8.8 and 9 inch. The 650hp Ford 331 would make short order of most smaller axles. Why not use the Dana 80's, which by the way are in huge abundant supply from Dodge to Fords. I found a set for $700 complete.
The whole idea behind this thread was to get some ideas about going big, safely and with some ideas about cost cutters. A Ranger can look cool wearing 44's for shoes but it can be functional as well.
snoranger
Professional money waster
ASE Certified Tech
13,674
Jackson, NJ
'79,'94,'02,'23
All Fords
2.3 EcoBoost
I'd be worried about 650hp from a 302 block.
montazch
Morgantown, WV
Sold
You know. All I'm getting here on this forum is heat, complaints and a hard time. I'm sorry I even posted the question.
Mickey Bitsko
Pagosa Springs CO>
live everyday like your gonna die tomorrow
Oh, I get it , you want to build something like everybody else and nobody will tell you how to do it.. well heck, I see why your upset:popcorn:
BabyBronco89
GR Michigan
95' 4.0 OHV
cut the negativity crap, theres nothing more fulfilling then helping someone else spend their money, and saying hey that was my idea, if he's got an idea of what he wants, then id say lets help him make it a reality.
i know every one on here did the same for me,
so stop the bashing, its obviously not a noob question, were not talking skyjacker or rough county bolt on crap.
if it were me and you want the tallest lift possible, i would probably be looking at fabbing a custom tube chassis under your frame, like a lot of the big mud digger trucks do, and sorta like monster trucks.
something like this
hope that helps
BabyBronco89
GR Michigan
95' 4.0 OHV
thinking parade status, you should consider 2.5 ton rock wells. all the slowness you need for a parade, will definitely handle 44s, plus who doesn't want rock wells
snoranger
ASE Certified Tech
13,674
Jackson, NJ
'79,'94,'02,'23
All Fords
2.3 EcoBoost
bobbywalter
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
Thanks!
:icon_welder:
how many guys that responded have trucks that run 44 inch tires?
you should carefully note that before cranking your sensitivity up.
i have a daily driver truck and it has run 44's. still can if i want t use them. of course to sensibly accomplish that goal i cut the fenders and run as little lift as possible...this unfortunately limits travel as well. my truck dont look cool though...it frightens most people.
so to have travel and to leave the fenders uncut the answer is obvious.
great advice here already a few posts back. for axles the 1st choice should be rockwells. they will by far be the most cost effective solution. easy to find 700-1500 for a matched set. start looking.
building dana 80's is a bad idea all around. not cost effective by any stretch in comparison....rockwells have huge aftermarket support. for the purposes you report, dana 44 8 lug and a dana 60 rear full float would work perfectly. stock 4.1 gears....real cheap to do.
suspension is another matter......
some easy range would be a minimal drop sub-frame and leaf springs. very easy to do.
you want links....also easy to do at this scale. start with some of the common 4 link calculators online and work from there.
the pic posted here from the earlier poster is a great start to your ends imo.....he hit it right on the head for ya.
thats how to build a show truck.:dunno: it is real simple.
all you need is a shit ton of MONEY to burn so you can go parading around as the occasions hit the calender. this example looks real reasonable on costs at that. we have 4-5 parades here per year and its a great way to support local issues and charities so i can see the goals as legit for sure.
conversely .... as a guy who also occasionally builds engines...specializing in fuel injecting windsors of all types and drives a ranger with 44 inch tires bitchslapping dana 60 parts into oblivion
and
went thru your past 70 posts these past years...simply because i was perplexed to say the least at the engine choice.
while mostly for sale stuff in the posts....i certainly had pause at, 6 months wiring, and...... how to measure or install hoodpins. paraphrasing of course.
i sure was curious why an engine builder would build a baby sbf for something like this. a 351....stroked maximally...yes. but a 331???
had you listed an exotic block like you picked apart the standard axle selection i would not have looked into the past posts....bit i was curious...
your choice of engine became understandable with the hoodpin question.
i do think for show purposes i would run a big block of some flavor. whatever the best deal was for a good running system...440 mopar, 460 ford, or a 454...fanblade to transfer case.
honest advice, :icon_thumby:
