tailhousing swap
steveoelo
Mighty Canuck
Is it possible to swap a tailhousing from a 91 3.0 to a 99 4.0 5 speed? Both are m50d 2wd but I need the cable hook-up from the 3.0. Is it a direct swap?
3,614
Should be. I can't think of anything else that changed on that end of the trans.
Mac
183
C. Wisconsin
2000
199
Will the '99' trans even have the hole and drive gear to accept a cable? Boss might be there but not machined.
Dave
3,614
Dave
I took it as him wanting to put the 91 tail housing on the newer trans. That should be possible, and then the drive gear would need swapped, but it is accessible just by removing the tail stock.
Mac
183
C. Wisconsin
2000
199
Yep, thinking bass ackwad again.
steveoelo
Mighty Canuck
Yeah I want to know if it's possible to put the 3.0 tailhousing on the 4.0
3,614
Yes, its' the other end of the trans that changes with the engine.
