Yeah, an '85 should have dual filament bulbs as the demon states. I've had quite a few problems with my '96 wiring being brittle. Are the license plate lights on? Front marker lights? All these run from the same place, but because yours has a flat bed I'm guessing someone has messed with the wiring harness in the past. If only the rear tail lights and license plate lights aren't working, it's time to start peeling back the black electrical tape and taking a look-see. I'm guessing that if both tail lights are not functioning it wouldn't be a socket. The wiring should run to the left (driver's side) tail light, but split off and go to the license plate lights and then the right side.
