Tachometer help please
Lazyace1975
I am in need of tachometer help on my 89 Ranger. Hit the ignition switch and it pegs out at 6,000 rpms and stays there til I shut it off. Help greatly appreciated.
8,371
Welcome to TRS :)
What engine is in your 1989 Ranger?
If you have a distributor then tach signal comes from Coil's "-" terminal
If no distributor then it comes from the ICM(ignition control module)
But...........problem is most likely the tach itself
Lazyace1975
Thanks.
2.3L
DannyG
9
Grand Forks, ND
If you are capable at soldering you can re-flow all the contact points on the back of the tach module.
The tachometers in the 89-92 Ranger and F-150s from that era are prone to solder point weakening and breakages.
No members online now.
