Sway Bar Missing Hardware?
shr3dd3r 09
Huntsville, AL
3.9L Inline 4 Cylinder Cummins 4BT
3 Inches
33X11.5X16 (285/75R16)
I have a 2000 Ranger 4x4. The other day I noticed that the "spacer" or whatever it is where the sway bar/anchor bar connects to the lower control arm on the passenger side is missing. There is a nut and a spacer of some sort connected on the driver side lower control arm where the sway bar (anchor bar?) connects, but the spacer is missing on the passenger side, like it somehow broke and fell off leaving the nut and about an inch of space or so between the nut and the control arm where the anchor bar pushes through. I haven't noticed any symptoms so I'm not sure how long it has been missing. Does anyone know what this part is so I can get a replacement?
On the driver side from the bottom of the control arm it is nut > "spacer" > control arm.
On the passenger side it is nut > empty space > control arm.
pjtoledo
2,966
Toledo Ohio
Fords
3.0 2.3
look up "end links" for sway bars or stabilizer bars at any online parts place for pics of what should be there.
they are a high failure item.
