Swapping 5.0 into manual explorer
blain
I am looking to get a 5.0 for my 99 explorer. It is currently a v6 manual with an r1 trans.
If I understand correctly, I can grab a 97+ 4.2 r2 trans to keep my shifter in the stock location?
Truck is and will remain 2wd.
Sent from my Z812 using Tapatalk
8,372
Yes, that would be correct, 4.2l V6 1997 and up M5OD-R2 had same trans bolt pattern as 5.0l.
And shifter was moved farther back in 1997 model year so within 1 inch of Explorer/Ranger R1 shifter location.
You can use older M5OD-R2 from 5.0l but you need to make a new floor hole for shifter and get shifter arm bent to fit and not hit dash :)
blain
With it being "within" one inch of the stock opening, how would I line that up without cobbling my stock shifter base? Is there a way to gain that inch through the way I'd mount the shifter?
