Swap disc brakes onto 92 explorer 8.8?
Sasquatch_Ryda
Forum Staff - Retired
108
Terrace, BC, Canada
Solid Axle Swap 4x4
40s
I was just wondering if it is possible to swap a 92 explorer 31 spline 8.8 over to the stock disc brake set up used by the 96's?
Jeepman401
CT
It can be done.
I believe joelH did it. Unfortunetly the info on it is probably gone now
Sasquatch_Ryda
108
Terrace, BC, Canada
Solid Axle Swap 4x4
40s
yea, was just wondering if it is a bolt on swap or what deal was
Jeepman401
CT
If I remember corectly, You had to grind a bit on the bracket to get it to work,
AllanD
TRS Technical Staff
135
East-Central Pennsylvania
1987... sorta
'93 4.0
Swapping the disc backing plates onto a '91-94 explorer axle is about as easy as such swaps get...
AD
TireIron
Methuen, MA
yea, if you have the backing plates and associtated hardware from the disk brake axle it should be about a bolt on swap onto the older drum explorer axle. The only thing you will have to work on is using a rubber brake line from each side of the hard line on the axle to each caliper to allow for the caliper movement.
Ozwynn
200
Berrien Springs, MI
RE Interceptor
or just swap in the 96 axle .... if the gear ratios match ..... took me about 1 hour to swap the whole axle on my 91 explorer. rates about a 1 on the dificulty meter.
Sasquatch_Ryda
108
Terrace, BC, Canada
Solid Axle Swap 4x4
40s
i already have the 92 axle
CopyKat
8
Manitoba, Coldest place in Canada
Yes the explorer drum can be converted by using explorer disc parts.
I've got 97 disks on my 94 axle. I've had 96 disk parts and they are identical.
Another thing to look at is the Grand Cherokee disks. I believe they are very similar. I know the rotors are near identical.
